The problem is dizzy (TFI/Stator sensor), wiring or ECM related......remove the SPOUT connector, crank the engine and check for spark and repeat the light test at the (-) pin of the coil.
the red/grn and red/blu are the ones going to the control module, when you say dizzy are you referring to the wires off the stator or somewhere else on the distributor
