cobra manifolds
cobra manifolds
finishing up install taken forever got to the throttle body and realized that the cobra manifold has the exact same bolt pattern on back as the egr spacer. Does this mean i don't need the egr spacer? if not what size bolts should i run from the throotle body to the intake manifold because the stock double threads wont do it.
Thanks
1991 Mustang Convertible GT
Thanks
RE: cobra manifolds
I just put one of those intakes on my car as well and since I have a whine noise coming from it... put on a 70 mm throttle body as well, no vaccuum leaks so unless the intake makes that noise i have no idea what it is?????
RE: cobra manifolds
ORIGINAL: ginoinontario
RE: cobra manifolds
Some of the larger T bodys need a very small bleed hole drilled into the plate because the airflow through them mimics blowing acroos a bottle making the noise you describe. There is also a spacer available to put inbetween the IAC motor that gives you an air bleed adjustment that may get rid of your noise. I fail to remember the part number but it is a Ford service part.
