Weird misfiring....
Old 04-02-2006, 11:32 PM
  #21
Tims 88GT
Tims 88GT's Avatar
Default RE: Weird misfiring....
hey man sry i was out.
timing steps
1. make sure the car is off
2. pull the spout connector out
3. put the lead on the #1 wire
4. loosin hold down bolt
5 start car, and set timing
6 turn car off and tighten bolt, DONT NOT MOVE THE DIZZY
7 put the sput back in.
Tims 88GT is offline
Old 04-03-2006, 12:49 AM
  #22
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Twisted
ORIGINAL: PRO50SC
Did it misfire before the plug change? Check the firing order. Maybe you crossed 2 wires.
What would happen if you crossed two wires, Pro50?
It would create a misfire.
PRO50SC is offline
Old 04-03-2006, 01:14 AM
  #23
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: 91fox
No, i was told i didnt have to gap these plugs.
let me guess... the parts store guys talked you into buying "Super Duper Quadro-triple Platinum"
never use anything other than copper or resistor style plugs.... everything else is GARBAGE.
unless you are running a VERY high HP or high tune machine.... then iridiums are very helpful. but at $7-$13 a piece..... it gets pricey
i run Autolite Resistor plugs.... i had a misfire with my platinums that the old owner had installed. the coppers made it go away.
and gap slightly smaller then recommended. my stock gap is .54 i gapped to .48
AdderMk2 is offline
Old 04-03-2006, 01:21 AM
  #24
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
^^ +1
i had iridiums too when i had my miss problem. i threw some cheap autolites in it and it runs great now. i gap mine to .50 instead of.54
FiveLiterRiceEater is offline
Old 04-04-2006, 12:35 AM
  #25
91fox
91fox's Avatar
YESS! success! Didnt have to mess with timing at all. Took out the autolites i just put in on saturday and put in motorcraft plugs today, and boy does it run verrrrry well. Way better than before i changed the plugs in the first place. Just thought i would let you guys know. Thanx for all the help
91fox is offline
Old 04-04-2006, 12:41 AM
  #26
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: 91fox
Hmmmm, that's odd. Aren't autolites made by Motorcraft, or visa versa?
PRO50SC is offline
Old 04-04-2006, 01:48 AM
  #27
AdderMk2
Banned
AdderMk2's Avatar
autolite WHAT.... i bet they were platinum
AdderMk2 is offline
Old 04-04-2006, 09:43 AM
  #28
91fox
91fox's Avatar
Yes, they were autolite platinum. And when i was taking the orginal spark plugs out, guess what they were? Yup, autolite platinum. It had just a tiny tiny misfire with the orginal autolite platinums. Put the new AL platinums in, got worse. Put the motorcrafts in, problem solved
ORIGINAL: AdderMk2
91fox is offline
Old 04-04-2006, 09:05 PM
  #29
AdderMk2
Banned
AdderMk2's Avatar
platinum plugs blow.... always run copper or resistor style plugs
AdderMk2 is offline
Old 04-04-2006, 10:43 PM
  #30
ddeaton66
ddeaton66's Avatar
The dropped plug.....when you drop them once...drop them twice, second time in the garbage. You run a high risk of the ceramic cracking inside the plug when they are dropped. I never take the chance, can show up immediately or just a little later.
ddeaton66 is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
mungodrums
09-28-2015 10:54 PM
2015Ecoboost
09-17-2015 01:48 PM
MasterLanMan
09-13-2015 08:21 PM
Quick Reply: Weird misfiring....
