Out of Ideas
04-06-2006, 12:51 AM
RE: Out of Ideas
Try the starting fluid. You could have dirty injectors that caused it to run and then die.
04-06-2006, 12:54 AM
The Rogue Mod
RE: Out of Ideas
Quote:
ORIGINAL: dsum14
Yes it ran normal. The first time I hit the throttle it was fine, it was the second time I hit it that it stalled.
Can you hear the f/p prime when you hit the key? Any chance you have axcess to a f/p gauge?
04-06-2006, 12:55 AM
RE: Out of Ideas
no fuel. wanna bet money on it?
04-06-2006, 12:56 AM
RE: Out of Ideas
I can hear the fp kick on. There is fuel in the cylinders. I removed the spark plug and could see fuel. I do not have access to a fuel pressure gauge.
The Rogue Mod
RE: Out of Ideas
Have you looked at any of the plugs to see if they are wet from gas?
04-06-2006, 12:57 AM
RE: Out of Ideas
The injectors are fairly new. I've had them on the car for about a year and only have maybe 200 miles on them.
RE: Out of Ideas
Yes, fuel on the plug.
The Rogue Mod
RE: Out of Ideas
Try to be more clear on the odd cranking problem. Try to describe it a little better.
RE: Out of Ideas
If you see fuel in the cylinder, you have flooded it. Pull the plug and smell it and see if it has fuel on it.
04-06-2006, 12:58 AM
RE: Out of Ideas
^^ lol he said they are wet, guess i lost. you have spark to right? is the motor cranking over fast or slow?
