Out of Ideas
Out of Ideas
Okay, I'm pretty ticked off right now. Weather got nice in Nebraska and I decided it was time to stop fiddlin around and get the stang back together. I took off the lower intake and replaced the gasket over the winter months and inserted all the necessary MSD components for good messure...6AL, Blaster, Dist. I stabbed the Dist. and timed the car to 12 degrees. I was letting the car idle for about 10 minutes while I was adjusting the idle rpms and letting all the old gas burn out of the lines so I could get it out and have the alignment done since I just replaced the struts, lowered it, hawk pads, and slotted/drilled rotors. I jumped in the car and gave it some gas...the rpms went up. I gave it a little gas again and the rpms went up and then slowly dropped even while I tried to give it a little gas to keep them up. The car died and now will not start. I've checked and have Spark, Fuel, and Compression...the three essentials for an internal combustion motor. I took the Dist Cap off and the rotor is turning. The car is making a funny sound when trying to start, it doesn't seem to be turning fast enough to start and has a level sound to it...kind of hard to explain. Does anyone have any ideas. I need help!!!! I know a little about cars, but this one is out of my league. My wife is mad at me now because I just reinstated the insurance on it and now cannot drive it. Please Help!!!
D
D
RE: Out of Ideas
I'll check that. I had thought that might be it, but wasn't for sure. Other ideas I've came up with are the timing belt jumped or the IAC is clogged. Think it could be one of those?
RE: Out of Ideas
The alternator wasn't the problem. I replaced it and it still won't start. I replaced the starter relay and the ignition control module and nothing is happening. Does anyone have any ideas? Got spark, compression, and fuel in the cylinders. Please someone!!! The weather is nice and I want to drive my car.
RE: Out of Ideas
ORIGINAL: dsum14
RE: Out of Ideas
ORIGINAL: Tims 88GT
try the battery. is the motor turning really slow? hey Bernie remember my post the other day WONT START. well i told you it could happen haha.
EDIT!!! Oh yeah, I remember it now!!![:@]
