3.73s and speedo gear?
I had planned on getting a set of 3.55s put in this week. I chose 3.55s because the owner of the shop who is doing the work says that the speedo can only be calibrated correctly with 3.55s or smaller (numerically). Although he seems extremely knowledgeable about 5.0s in particular, I was under the impression that you can get the correct speedo gear for any size gears, including 3.73s. Can anyone confirm or refute what the shop owner has told me? Thanks.
RE: 3.73s and speedo gear?
That's what I thought. I've done a search on this site, and it seems that you can calibrate the speedo correctly with 3.73s. I just wonder why the owner said that considering all the 5.0s he's worked on.
Well I have 3.73's and im in desperate need of a new speedo gear because when im going 70 on the interstate im really going 63. My friend clocked this saturday night. I know that the 21 tooth is for the 3.55 so im guessing that I would need a 24 tooth? In my 50resto book for 79-93 stangs, they only carry up to a 3.55 speed gear.... So does anyone know where I could find a gear for 3.73's?
You can get the gear from someone online I am sure. Just look around. I got mine from my local Ford shop. Ttransmission shops can get them, if they dont have them on hand. Here is the information I found online about the different year mustangs, and the speedo gear needed for different rearend gears. I hope this helps you guys out.
Speedometer Gear Help Guide
Ring & Pinion Speedo Gear Part Number
1983-89 Mustang Manual 5-Speed
3.08 18 Tooth LRS-17271H
3.27 19 Tooth LRS-17271A
3.55 20 Tooth LRS-17271B
3.73 21 Tooth LRS-17271C
4.10 23 Tooth LRS-17271D
1990-93 Mustang Manual 5-Speed
3.08 20 Tooth LRS-17271B
3.27 21 Tooth LRS-17271C
3.55 23 Tooth LRS-17271D
1984-89 Mustang Automatic AOD
3.27 19 Tooth LRS-17271E
3.55 20 Tooth LRS-17271F
3.73 21 Tooth LRS-17271G
4.10 23 Tooth LRS-17271J
1990-93 Mustang Automatic AOD
2.73 19 Tooth LRS-17271E
3.08 20 Tooth LRS-17271F
3.27 21 Tooth LRS-17271G
3.55 23 Tooth LRS-17271J
1996-98 Mustang Cobra Manual 5-Speed
1994-98 Mustang Manual 5-Speed
Except 1996-98 Cobra
1994-98 Mustang Automatic AOD
I also had to replace my speedo gear in my 87 GT Conv. unfortunately with an automatic though. I put in 3.73 gears and had to switch out to a 23- tooth speedo gear to bring the speedo back within range. Each tooth equals about 5 miles an hour, just fyi.
