driving 70mph, speedo says 120mph
Old 04-04-2006, 05:20 PM
FoMoCo
FoMoCo's Avatar
Default driving 70mph, speedo says 120mph
Im buying another 5.0 and this is happening: Driving 70mph @ 2600 RPM and the speedo says im going 120mph. Does the car have gears.
FoMoCo is offline
Old 04-04-2006, 05:25 PM
5.0FoxBody
5.0FoxBody's Avatar
Default RE: driving 70mph, speedo says 120mph
If you know you were actually goin 70mph and the speedo said you were goin 120...then yeah...you probly have gears... is it a five speed? if it is...probly has 3.73s...rpm is fairly low for that speed if it has gears....in an auto anyways... if the owner doesn't know...then...:S I dunno whta to tell ya other than just try gettin a new speedo gear to see if it fixes it.
5.0FoxBody is offline
Old 04-04-2006, 05:26 PM
90Mustangfan
I ♥ Acer
90Mustangfan's Avatar
what gear are you in, if in 5th wounds like you have 4.10 gears, or 3.73, if you want to find out if you have gears, you can jack up the car, make sure both rear tires are off the ground, remove parking breaks or put in neutral. the mark a spot on the Driveshaft, the see how many times the tire rotates per 1 revolution of the drive shaft. if you can turn it 3 1/2 times you have 3.55's if you turn it more than 4, you have 4.10 gears.
90Mustangfan is offline
88BlueGT
88BlueGT's Avatar
Check to see what gears you have
88BlueGT is offline
Old 04-04-2006, 05:28 PM
primetime5.0
primetime5.0's Avatar
someone could have put a 140 face on an 85 speedo, thats how mine is
primetime5.0 is offline
88BlueGT
88BlueGT's Avatar
^^ Good thinking... I never thought about that. Thats right about wher it would be also... Good thinking PrimeTime
88BlueGT is offline
Old 04-04-2006, 05:29 PM
FoMoCo
FoMoCo's Avatar
it's a 5-speed and im in 5th gear. I compared the speed with another 5.0(stock). i'm guessing 3.73's. I don't think is was an 85 speedo because this is a '93 5.0.
FoMoCo is offline
Old 04-04-2006, 05:30 PM
primetime5.0
thanx, i work out
Old 04-04-2006, 06:37 PM
88BlueGT
88BlueGT's Avatar
lol hah
88BlueGT is offline
Old 04-04-2006, 08:30 PM
Crazyfast50stang
Crazyfast50stang's Avatar
well try what was said earlier about the driveshaft and such.
Crazyfast50stang is offline
Nick Oliver
10-17-2018 04:22 AM
zsmart
Convertible Tech
02-29-2016 08:33 AM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
09-08-2015 11:50 AM
Quick Reply: driving 70mph, speedo says 120mph
