A/c Delete
RE: A/c Delete
they coved, it you also might get the kit that move the PS pump up to where the a/c was...it the better kit than gettting the kit which leaves the P/s pump in same place, and just adds a pulley where the a/c goes those kits arent as good.
RE: A/c Delete
Not sure where you live, but you might even go to 50resto.com and look into their a/c and smog delete kit
It comes with underdrive pulleys for water/crank/alternator, a new bracket to relocate p/s pump, bracket for smog delete, and the belt you need to make it work with those two o items gone... It will definitely add about 20hp to your car, and lose about 70 lbs... off the nose which is a good thing...
Now if you don't want to go through all of these things, and just do the a/c delete, you can buy just the p/s relocation bracket for about 45 bucks, and a new belt for about twenty. To do it right and do it yourself, you will also need to buy a specialty tool that allows you to remove the a/c lines with just cutting them, and of course the dust caps for the two non-connected lines sticking out of the firewall. Hope this help you. Good luck.
RE: A/c Delete
SUMMIT
I just bought the ford racing delete for my 94. it uses the same belt and its a 3 bolt install. Oh and pepboys sells the tool to remove all the ac lines, it worked great but other than that the ford racing kit got my thumbs up!!!
FMS-M-19216-A50 <------part number for the one you need, hope this helps!!
