Rebuilding engine..
RE: Rebuilding engine..
...you're running 13's with that setup? got any slips? anyway, of course it will make it stronger as long as you do it right. faster?...maybe...13's is pretty frikin fast for what you have.
I suggest the rebuild kit from summit with forged pistons.Its a damn good kit.
As for your crankshaft its stock and orginal (NEVER BEEN REBUILT BEFORE) i would have it turned 10 thousandths.
Before ordering that kit though decide whether or not you are going 30 over,40 over or 60 over.Those are the most common but you could even go as light as 20 over but i suggest 30 over unless its been rebuilt before and then i say 60 over.
Depending on how involved you get this thing could BLOW your mind if you take your time and do it right.Are MECHANICALLY INCLINED?Ever ported a head?How much can you do on your own?Whats your engine building history?I will tell you that your E7TE heads can be made to flowwith most aftermarket head for a fraction of the price as long as you are able to di it yourself.Theres many tricks to the trade to get more power its just a matter of picking the right combo.
all this talk about rebuilding adds up.. in looking through a couple magizines i saw and ad for rebuilt engines. How good or bad is the buying a complete rebuilt engine compared to rebuilding yours? What are some of the pros and cons? ik thinking of rebuilding but wieghing my options..
it depends on what if anything you change when you rebuild it. if you don't change bore and stroke or cam or heads, you will be back to new stock condition. if you had a lot of mileage on the motor, this could be some increase in power depending on how old the motor was.
what happened to the lifters? did the lifter bores get damaged? did metal get into the oil pan? did the engine lock up? you will have to take the engine apart and examine the bearings and crank for wear/damage. also the cam and its bearings. once you have a better idea of what the total damages are, then you can get a better estimate on the cost.
if you don't have the experience of rebuilding an engine, then you have a choice to make:
1) go for it yourself and learn by trial and error or
2) buy a rebuilt shortblock and start from there or
3) buy a good used engine from a salvage yard and install it
4) buy a new crate motor and install it
The final choice is up to you and your wallet to decide which way to go.
either way my guess is somewhere between $1,000 to $4,000 depending upon what damages you find and the final choice you make
remember "speed costs money, how fast do you want to go???
How can you tell if you need to bore it? I have a bit over 150K on my engine and I would like to rebuild the engine before I leave the island. I am gonna get the forged piston kit from summit but I don't want to bore it if I don't have to. I've never done it and I don't trust any mechanics here (to do it right or to not overcharge me). Also what else should I get when I the kit to add a little more reliability and hp without raising the gas milage (gas is between $2.20 - $2.50 for regular here)? Cam? Timing gears? If so, what type? I have new headers, cold air intake, and I am going to upgrade to 130 amp alt as soon as I can figure out the wiring. Thanks.
