need fast Q, wanna buy my meter
RE: need fast Q, wanna buy my meter
I would say you could PROBLY go to any local salvage yard and get the stock 19lb injector sensor for hella cheap...then..you'd pretty much be set if you say you have the stuff to convert it to MAF
probly find any fox body 'stang w/ a 5.0...but any 5.0 from around that time frame should work...:S I'm assuming anyways...lol anything from a 5.0 Bronco...or 5.0 Crown Vic...??
The price on ebay should be 206 or go to www.blueovalindustries.com and click on the induction tab then go to cold air intakes and click on your year, it will also be 206 there, that comes with box, K&N filter, true flow inlet and 76mm MAF. The reason it works better then others is because the TRUE FLOW INLET is 70mm the whole way, thats why its "true"
ORIGINAL: 5.0_GT
what cars had the same maf or what cars did they come in
09-25-2015 06:30 PM
09-25-2015 09:06 AM
