PCM Question
Old 04-06-2006, 01:10 AM
jknowles249
jknowles249's Avatar
Default PCM Question
How do you know when your PCM is bad? Will your car even start? I put in a new starter a couple of days ago and during the process I touched a hot wire to ground. And after I got the new starter installed my car will barely even rev up let alone have enough power to drive somewhere. Any ideas on this? Electrical Mechanical?
jknowles249 is offline
Old 04-06-2006, 01:17 AM
Tims 88GT
Tims 88GT's Avatar
Default RE: PCM Question
to check for a bad computer, try to set the tps it will read 4.95 volts. but that could also mean it has a bad ground so check them.
Tims 88GT is offline
Old 04-06-2006, 01:20 AM
jknowles249
OK! Isnt there some way to test for electrical shorts with a test light between your negative post and the negative cable?
Old 04-06-2006, 01:22 AM
Tims 88GT
Tims 88GT's Avatar
sure, but i dont know how lol. i just take the grounds off and clean them.
Old 04-06-2006, 01:24 AM
jknowles249
So if the voltage at my TPS is anything but 4.95V, The PCM should be replaced?
Old 04-06-2006, 01:26 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: jknowles249
That is to test for a draw on the system.
PRO50SC is offline
Old 04-06-2006, 01:27 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Tims 88GT
Clarify! News to me.
PRO50SC is offline
Tims 88GT
Tims 88GT's Avatar
if its 4.95v or higher it could be a bad ground. if they are ok its the computer.
Old 04-06-2006, 01:28 AM
jknowles249
What the test light between the neg cable and post? Yea I know, would that affect my computer?
Tims 88GT
Tims 88GT's Avatar
the tech at the ford dealer told me that. it was news to me to, but my tps did that when i fried my computer. he said it could be a bad ground to, now if u unplug your egr it will do the same thing.
Quick Reply: PCM Question
