COld start when 30degrees or below
When it is 30 or below outside and i start the car for the first time it will die then i will start it again it will die. Then it will run at like 500 rpms surge to like 1200rpms for like 1min then start to finally idle normally.
When it is above that temp the car will start up and not die and run a little low at first but not at 500 then like 1 min later it wil run like normal. Could it be the Ect? i took it out and tested it on high temps and it was right around the range restitance it should be in. anyone have any suggestion. Should i test the ect at colder temps and see the resistnace or would it not have any difference?
09-01-2015 08:16 PM
