Transgo shift kit question - 2nd try
Tried the general forum and got nuthin'. Give this forum a shot.
hello all,
I am looking into getting a transgo shift kit. 95 gt auto (aode). I was looking at the transgo website and found the right one i believe.
SK®AODE
(4R70W)
AODE 91-04
Ford/Mercury
Lincoln 94-up
Mustang, T-Bird,
Bronco, Lt Trucks
Calibration and Assembly Upgrades. Installs in 10 minutes. Crisp but Smooth Shifts. Corrects/Re-duces/Prevents: 4th band failure; 2nd roller failure; long soft 1-2 and 2-3 shifts; soft lockup; reduces accidental high-pressure parts breakage. Special Hi-tech fwd clutch rings, SOL regulator valve & EPC relief. For firm shifts use AODE-HD2
So, my question is, does anybody know the difference between the SK Aode ad Aode-HD2. In their description, is says "for firm shifts use AODE-HD2". Maybe the SK AODE is for rebuilding an old tranny or something- it says it installs in 10 minutes, but the kit installs in like 4 hours, right? I plan on doing it myself, cant be that hard.
Another question i have is, does the shift kit make kind of "jolt" you in the car when its shifting (while just cruising)? My dad has a roadrunner with a shift kit and that damn thing really clunks into 2nd and 3rd. I havent road in a newer stang with a shift kit in it, but I know that mine is pretty lame as far shifting- kind of just coasts into gear.... Thanks
hello all,
SK®AODE
(4R70W)
AODE 91-04
Ford/Mercury
Lincoln 94-up
Mustang, T-Bird,
Bronco, Lt Trucks
RE: Transgo shift kit question - 2nd try
I have a transgo shift kit and it has been over a year and still loving it. About doing it yourslef, make sure you read the instrcutions carefully and pay attention to detail, it is very important if not then you might be towing your car to a tranny shop.
Good luck and you will not be dissapointed. About the two models of kits, I do not know the sk model I have the aode hd2.
Doing great, today i found out how nice some good rubber is, it was the first time i ever got to put the power to the ground in 1st and 2nd since i built the motor. WoW what a feeling
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-01-2015 08:16 PM
