MSD Ignition
MSD Ignition
My msd is acting up, it will start then when I shut it off it and let it sit, then I will try it and it wont turn over. Then I let it sit and it will start. Could my coil be going bad? Oh yeah my plugs are relatively new.
RE: MSD Ignition
are you positive its your msd? could be a dozen other things causing that problem. if you wanna rule out the msd box, disconnect the wires and bypass it, and see if its still there. if its still there, i would guess a fuel problem, is it only when the car is warm or all the time?
RE: MSD Ignition
ORIGINAL: preciousroy
bradleyb
11-27-2015 07:50 PM
jessicarabbit
09-25-2015 12:41 PM
