Explorer Intake?
RE: Explorer Intake?
i've seen other "explorer" intakes listed with " 5th runner drilled and tapped for air temp sensor " listed on ebay before.
sound like the fix you need.
dont know on the egr stuff.
ORIGINAL: fordracing1122
So i would need the egr plate and what other egr stuff?
How would i make the Air Charge Temp sensor to work?
Thanks for the help!
the EGR spacer can be blocked off, but you need it for everything to bolt up right. The 97.5+ Explorers/Mountaineers moved the ACT sensor between the MAF and TB, but if the bung is still there, you can just drill and tap it. The bits would be less than $5 at Home Depot. If it's not there....well just read this....scroll down to the part about installing the Exploder intake....
Exploder Intake Install
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
