HELP INSTALLING MOTOR MOUNTS! Pls, Thx
Hey guys!
I'm finally going to install my new motor mounts on my car. So I need to know where I can bolt on the chain so that I can pick the motor up, and how far up do I need to lift it so that I won't damage anything and have enough clearance to do the swap.
Thanks alot guys for your help
Ben
RE: HELP INSTALLING MOTOR MOUNTS! Pls, Thx
If you have a floor jack, place a piece of wood on it and jack it under the pan, only need to raise it enough to unbolt the old ones and slide them out. Or you can jack it under the k-frame. Becareful of the fan hitting the shroud when lifting the motor. May want to unbolt the schroud.
