3.55 or 3.73
RE: 3.55 or 3.73
Man I am thinking about a new set myself, I see that I can get 3.73 from 5.0 Resto for $150, while the 4.10s are $180. How hard are these things to install, and should I get a rear end master bearing kit while changing this?
RE: 3.55 or 3.73
I work at BMW, and have access to a lift so that isn't a problem it if is necessary to use. As it what else is required to install one besides fluid, I was reading the instruction from ford and it seems that I might have to a get a kit that includes bushings. Also summit has 3.73s for $145, free ship +$10 tax for me. I look at my door tag and it said M, which is 2.73, you think 3.73 is a pretty big difference, I think it would. I have an AOD.
RE: 3.55 or 3.73
You'll need crush sleeve, ring gear bolts, pinion bolt, shims, and pinion seal at the minimum. I ordered a kit off Summit from ratech for about $35 that includes all that. The Ford racing ring and pinion gears included pinion shims, crush sleeve, and pinion nut, but no carrier shims.
RE: 3.55 or 3.73
i have 373 in a 5 speed, i liked them untill i installed my sc, when i blow my reaer i will go down to a 355, im running out of first gear way to quick, however... if i had an auto, and didnt have to shift myself, + extra hp loss through the auto i wouldnt hesitate to go 410.
