would a 6 speed be worth it?
So i am debateing weather or not to get the t56, or the t3550. So i guess the question is, would the six speed be worth the extra money?? I am running 3.73 and will soon have a stock 351 with a lumpy cam, so do you guys think that the t56 would be worth the extra money?
RE: would a 6 speed be worth it?
the last gear in a t56 is close to the same overdrive ratio as a t5 , so so in top gear its almost the same as a t5, and since you race 1-4 gears , i dont rec pounding on a overdrive gear , you just have a closer spread between your last gear
t5 t56
1 2.95 2.97
2 1.94 2.07
3 1.34 1.43
4 1.00 1.00
5 .73 .80
6 .62
the stangs i have made i set up to be done in 4th, 5 is just to help me get around town , unless you plan on road racing where you can really benifit from the extra gear then ya, but unless your not i dont go into the entire trouble of putting a t56 in . (extra work) i guess it depends on the car your making , if its a dragtype street car , i dont think you will ever really use the extra gear. im not putting the t56 down its just more work and hassle then getting something like a tko, or something else that can just bolt in . i just dont think people see that they really dont need the extra gear . but it all up to you and your preference, just pointing something out that i have experenced
t5 t56
1 2.95 2.97
2 1.94 2.07
3 1.34 1.43
4 1.00 1.00
5 .73 .80
6 .62
just go with putting in a whole new gear set, cheaper than the T56 and can handle more power. Go with G-Force look them up. They sell kits that slide right into the T-5 housing.
I'm going to change out the T5 in my car for a T56 this fall... Not only is it cooler, but the durability factor behind my new bigger engine will be the real reason...
mardyn
mardyn
depends on the year of you mustang yours is a 92 so it can handle 300 hp http://pages.prodigy.net/al.martin/T...d-T5-Data.html
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
BeatnikFink
10-01-2015 08:00 PM
treesloth
09-28-2015 07:03 AM
