87 mass air conversion. 89ecm vs. 90-93
I'm trying to piece together a mass air conversion for an 87 gt. Can I use any mass air computer or can I only use a non-airbag mass air (89)ecm? Is the harness jumper (plug) the same with the airbag? If so are the wires in the same order on the airbag ecm? Can I bypass the air bag in a 90-93 ecm and still get clear (11) koeo codes?
Please any info or opinions would be greatly appreciated
RE: 87 mass air conversion. 89ecm vs. 90-93
you may be able to ohm out the air bag and just splice that into the wire , newcars that have optional side air bags use simulators if it not equiped , i have always found thet correct pcm , but that may work , i would suggest an a9l if your not goinng to tune it . you dont have to get an entire harness , you can just switch some pins around on a non maf car get a connector and wire to plug into a maf , easy and cheap , vs buying a harness off some one , granetili makes them , and there write up on which pins to relocate .
I just pieced together a mass air setup for my 88. I used a ecu out of a 89 GT Auto.. and the rest of the mass air hardware. I purchased a wiring harness off of ebay.. it was like $32 shipped. The company who makes it is pretty good and gives you instructions on how to install it. Well worth the money. There is a tech wrightup on stangnet.com also that helped me with the stuff that the companys instructions didnt. It was pretty painless, I would go that way
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
