Water Pump/Timing Cover
Replaced the cam this weekend and after reassembly--put fluid in the radiator, it all came pouring out of the water pump. Took it all apart, tried it again, same problem. Got a new water pump, same problem! I'm not talking about water coming out of the weep wholes behind the timing cover (though water does come out there); I'm saying it leaks like it's not bolted. Bolts met torque specs, new gaskets, tons of sealant. Chances that the timing cover is cracked, warped etc. seems far fetched. What gives?
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
