aftermarket cd player
Old 04-10-2006, 08:27 PM
mattgt1000
mattgt1000's Avatar
Default aftermarket cd player
trying to install a brand new Alpine9856, everything works except im getting no sounds from the speakers, best buy say i have an amp inside that i have to override or some bs, anyone have any ideas on what to do
thanks
mattgt1000 is offline
Old 04-10-2006, 08:30 PM
RawGtPower
RawGtPower's Avatar
Default RE: aftermarket cd player
I installed mine. Did you connect the correct speaker wires to eachother. I had no sound either, until i messed around with the speaker wires, then i got some sound.
RawGtPower is offline
Old 04-10-2006, 08:31 PM
Drexl
Drexl's Avatar
ORIGINAL: mattgt1000
thanks
nice choice of deck... full speed ipod connection on those things rock.
you sure you have the correct wiring harness?
Drexl is offline
Old 04-10-2006, 09:34 PM
hotstang97gt
hotstang97gt's Avatar
if your not getting sound then you have the wires hooked up wrong to the speakers
hotstang97gt is offline
Old 04-10-2006, 10:57 PM
ZachW04Stang
ZachW04Stang's Avatar
I hooked up a jvc and it came with a wiring harness, everything hooked up fine and no problems. I was able to swap it out for a pioneer and still no problems.
ZachW04Stang is offline
Old 04-10-2006, 11:33 PM
ho85GT
ho85GT's Avatar
Well if ur car came w/ fords premium sound system then u have an amp up in the middle of the dash, ur system is wired in common ground also, u need the correct wiring harness for the deck and usually another one thats used to bypass the amp. I would just bypass the amp and connect the speakers directly to the deck w/o a harness.
ho85GT is offline
Old 04-11-2006, 12:21 AM
powerkord
powerkord's Avatar
if you still dont have it, try posting in the audio section. thell probbably have a simple solution 4 you
powerkord is offline
Old 04-11-2006, 12:50 AM
olsonk_89
olsonk_89's Avatar
I know exactly what your problem is. I had the same problem with my 93 before I sold it. What you need to do is bypass the factory amplifier. I believe that it is behind the radio area. This is the adapter that you need. If you select your car on their, they will include a paper that tells you everything you need to know including taking the factory amp out, and how to bypass it. On that webpage, there are actually 3 adapters included. What you are really after is the middle adapter in the picture. If by chance when you bought the wiring harnessr that you already wired into your car and you have that third adapter unused there is no reason to buy another one. If you do, I can find the install papers I think I have a copy of them from when I bought it from them. I hope I'm not confusing you, but trust me, I know what I'm talking about. Be sure to post any questions you've got, I'm here to help.
olsonk_89 is offline
Dan04COBRA
09-30-2015 11:46 AM
wraith777
09-28-2015 10:49 AM
09-24-2015 09:18 PM
vbonina
09-22-2015 08:31 AM
BOBCATJACK
09-14-2015 02:18 AM
Quick Reply: aftermarket cd player
