intake heads and cam
Im thinking abount getting a cobra intake, gt-40x heads, and a lunati voodoo cam, but on the cam i dont know what the duration and the lift means. How does that affect the heads and intake?
RE: intake heads and cam
Post up the #'s for the lift and duration @ .050.
If you're going to spend the money on heads, do not get the X's. The only real advantage to them over GT40 P (iron) heads is that they are aluminum. The P heads flow almost the same #'s.
CLICK HERE FOR PROOF
Instead, get the Trickflow TW's or AFR 165's. You will be MUCH happier w/ them.
ORIGINAL: Jasperstang308
according to that the edelbrock victor heads are some of the best. if thats the case why does everyone always say afr for?
i have the edelbrock vic jrs. theyre alot of head for a slightly modded motor. a cobra intake will never feed them. you would need a rpm II intake and prolly a 70mm tb and 76mm maf. to feed them the air they need.
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
