GT-40 302
GT-40 302
I can get my hands on a 5.0 out of a 1998 Mountaineer that has been wrecked. The motor its self was not damaged and still cranks. The car has 230,000 miles on it but I plan on boring it .30 over anyways. My question is would 400 be a good price? And is the block even the same as the EFI's in the Mustangs with the 5.0's? I plan on dropping it in a Fox or an SN. Preferably a 94-95 GT. Advise and information greatly appreciated.
RE: GT-40 302
I don't think it's a bad deal. How much will it cost you to rebuild the block? You'll need at least a stock mustang 5.0 cam, if not an E cam or TFS stage 1.
It will have the GT40 P heads on it, which flow decent #'s for stockers. Get a valve spring kit and roller rockers and you can have a pretty decent motor in no time.
If it has the intake on it, you'll be another step ahead b/c the stock Exploder/Mountaineer upper flows similar to a cobra upper and uses basically the same lower intake.
RE: GT-40 302
Well I have to pull the motor myself (But the car is wrecked so I can just cut alot of sh*t). I don't mind motor work and swapping parts but how much will I have to change to bolt it into a 5.0 stang or a 94-95? I figured I'd get the spring set and do a 3-angle valve job and port&polish the intakes. If I bore it to a 306 will the heads and intake still work suitable? ANd be able to handle N2o?
RE: GT-40 302
i found a motor here for 250$ and a 36,000mile engine from the yard with a warrant for only 850$ i say its kinda high although the intake sell on ebay for about 250 and the heads around 300?
RE: GT-40 302
ORIGINAL: NightmareStang22
Galactic
04-29-2019 02:56 PM
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
