World Products - Windsor Jr. heads
#31
RE: World Products - Windsor Jr. heads
ORIGINAL: capri331
Well as much as TW heads will be a step up you shuld consider a few things. One is that with WinJR heads you can easily locate a set in the $500 range. You could use them for a year or 2 and still sell them for the same $500 you paid. Also, you would be making a switch to a stud roller rocker and that would mean you could use those on the TW heads too. Another thing you don't want to do is have a set of wind tunnel heads on a block that can't make use out of a cross breeze Read the MM&FF article that I posted from the AFR articles section. It's a long series and if you don't have broad band you'll wish you did but that 8-9 month issue series is unmatched in SBF head testing and information bar none. I just wish that it would include some other heads we have out now.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
