What should I do w/ my money?
I just received my COMPLETE Trick Flow Top End kit (TW heads, Cam, timing set, Track Heat Intake), #24 Ford Racing Injectors w/ matching 75mm MAF, 70mm BBK TB, 255lph fuel pump, Aeromotive ADJ. FPR, FRPP waterpump, King Cobra Clutch, Ford Racing adjustable clutch cable...
What should I spend the rest of my money on?
I have a 100% stock block that I am going to use if I choose not to do the stroker block.
I also don't want to blow my stock block to pieces.
Leave comments as well as votes!
RE: What should I do w/ my money?
ORIGINAL: Stevens91gt
dont do looks..if ur car is the fastest mufuc*a then it doesnt matter
If you want to pick up chicks def looks,If you want to pick up older guys who love speed and hp,Then go performance
This is just my opininion, but spend the money on making the car faster. If you spend more money to make it look faster than it really is, you've defeated the purpose and wasted the aerodynamics of the body kit designed to keep you on the ground at higher speeds. It's kind of like these kids taking a FWD civic and putting a racing spoiler on it. Spoilers are designed to produce downforce at higher speeds.
Besides, speed is more fun....
