turn signals not working
RE: turn signals not working
LOL SHT!! I had that same problem for a month! DUDE, you gotta find your Turn Signal Flasher. Which is somewhere hidding behind where the radio is on the passanger side. Or its behind your glove box.
[IMG]local://upfiles/33089/C0FA0E5364844BB98911303D099CD75B.jpg[/IMG]
I had the same problem on my 87 LX. It has two flasher fuses. One was in the fuse box (emergency flashers) and another was for the turn signals. It was loose up in the dash behind the fuse box. Hope this helps, Good luck.
Listen. its your turn signal flasher, but in my 88 it was located directly below the steering wheel column just to the left of it. You will need to reach under te dash to get it. If you remove some of the lower trim on the under side of the column and use a flashlight you should be able to see it. It is probably attatched to a metal part of the column frame. Just pry it loose. Then you can put your new one in and move that relay to a closer location and secure it so it will be easier to reach next time.
