sd v.s mas
RE: sd v.s mas
Convert to mass air. Basically, speed density uses vacume measurements, and sensor inputs to determine what the timing advance and injector pulsewidth should be, and when you do performance modifications, speed density has no way of knowing there is more air and fuel needed.
Mass air actually meters the air coming into the engine, so that it can correct the air/fuel ration based on the air flow, rather than just some tables and graphs in the computer.
