1995 5.0 Auto Tranny Shift Issue
Old 03-16-2004, 01:33 PM
SeanKaneFLA
SeanKaneFLA's Avatar
Default 1995 5.0 Auto Tranny Shift Issue
Hi Everyone,
I'm experiencing an issue with my 1995 Mustang GT 5.0 w/auto tranny. The transmission delays when shifting from 1st to 2nd and then 2nd to 3rd. The engine revs up and if I let up on the throttle it will eventually shift on its own. I am able to manually shift from 1st to 2nd then third, etc. Any ideas? Is there a sensor that could be bad? Has anyone else seen this? This is under normal driving, not gunning it. Also, this is an overdrive transmission.
Thanks in advance.
Sincerely,
Sean Kane
SeanKaneFLA is offline
Old 03-16-2004, 09:53 PM
Milky
Milky's Avatar
Default RE: 1995 5.0 Auto Tranny Shift Issue
Could be the clutch slipping or the gears going out... Basically your going to need to rebuild the tranny. Don't drive the car very hard and it will last you a while if you flooring it, your waisting reusable parts in there for the rebuild.
Milky is offline
Old 03-16-2004, 10:23 PM
94mustang2003
94mustang2003's Avatar
well i have a 94 with auto my 3rd used to do the same thing it wouldn't shift unless u let go of the gas then gave it more gas it is just that your gears are going it happened to me so i would get it checked out
94mustang2003 is offline
Cannibal_carnies
03-02-2023 06:17 PM
ShaneB26154
35
03-04-2021 04:05 AM
Urambo Tauro
09-07-2015 12:47 PM
Stilz
08-18-2015 09:40 AM
Greyshot
08-15-2015 03:32 AM
Quick Reply: 1995 5.0 Auto Tranny Shift Issue
