Best way to grenade a stock GT rearend?
Old 03-16-2004, 06:41 PM
Shantymac
Shantymac's Avatar
Default Best way to grenade a stock GT rearend?
Is it possible to blow the T-5 trans or the sock 8.8 rearend with a nearly sock motor?
What would one need to do, lite the tires on a real steep hill a few times?
Shantymac is offline
Old 03-16-2004, 06:43 PM
Shantymac
Shantymac's Avatar
Default RE: Best way to grenade a stock GT rearend?
I want to get some new gears and axles so i want to see how far the stockers will go
Old 03-16-2004, 06:46 PM
Shantymac
Shantymac's Avatar
Also why does the tranny feel so solid, when i lite em up at the line the shifter hardly moves at all!
Old 03-16-2004, 06:53 PM
50fiend
50fiend's Avatar
It's very easy to kill a T5. Just don't use the clutch. T5s are not all that solid. They like to be pampered. Although I'm not sure why you would what to kill your transmission. I would imagine that the transmission would go before the rearend so if you hammer it you will have the expense of rebuilding the transmission while the rearend is still in good shape.
50fiend is offline
Old 03-16-2004, 06:58 PM
Shantymac
Shantymac's Avatar
how long will it take powershifting to kill the trans?
I want to get a tremec TKO
Old 03-16-2004, 07:05 PM
50fiend
50fiend's Avatar
I don't know how many shifts it would take. It depends on how good you are at it. You do know, you can make money by selling the transmission. Sometimes you may need to use it for a core on a new transmission. Remember the Tootsie pop comercial where the Owl finds out how many licks it takes to get the the center of a tootsie roll tootsie pop. This thread kinda reminds me of that.
50fiend is offline
Old 03-16-2004, 09:44 PM
TheGmKiller331
I ♥ Acer
TheGmKiller331's Avatar
This is ignorant!I would be more worried about trashing the motor and the rest of the driveline.
I dont think anyone would do that here we all have more sense than to purposely trash our vehicles because we want new parts.You want better stuff upgrade why trash what you have in order to get new?
Remind me to not let you ever barrow my mustang!
TheGmKiller331 is offline
Old 03-16-2004, 09:57 PM
Milky
Milky's Avatar
I'd hit about 80 on the freeway and trying slamming it in reverse a few... dozen times... let me know how it works out
Milky is offline
Old 03-16-2004, 10:20 PM
VertStangGT86
VertStangGT86's Avatar
OK, if you want new stuff get it and put it in, sell your old stuff to someone cheap instead of wrecking it, do someone else a favor and make yourself a little money. If you want new gears and you're trying to mess up the rear end you'll probably damage more then just the ring and pinion.
VertStangGT86 is offline
Old 03-16-2004, 10:23 PM
Obsol3te
Obsol3te's Avatar
Oooooooo wait!
try a 150-200 shot of nitrous in Reverse!
Obsol3te is offline
Quick Reply: Best way to grenade a stock GT rearend?
