oil pan removal
Old 04-17-2006, 07:10 PM
tuff5liter
tuff5liter's Avatar
Default oil pan removal
Anyone care to seuggest the best way to remove the oil pan on a fox body with the motor still in the car? I was reading my chiltons and they were suggesting removing the steering gear, the oil pump and the pickup assembly and the x pipe and blah blah blah.....soes anyone know of an easier way to do this?
tuff5liter is offline
Old 04-17-2006, 07:11 PM
dc_mann8
dc_mann8's Avatar
Default RE: oil pan removal
unbolt the mounts, lift it up about 4 inches, pull er off.
dc_mann8 is offline
Old 04-17-2006, 07:13 PM
ZachW04Stang
ZachW04Stang's Avatar
ORIGINAL: dc_mann8
This will give you enough room to get it out or just replace the gasket?
ZachW04Stang is offline
Old 04-17-2006, 07:14 PM
tuff5liter
tuff5liter's Avatar
no need to unbolt the oil pump or anything else??
Old 04-17-2006, 07:19 PM
1990mustanggt
1990mustanggt's Avatar
The oil pump is inside the pan. Just lift the engine up about 5 or 6 inches then pull the pan off.
1990mustanggt is offline
Old 04-17-2006, 07:21 PM
FoxRod
FoxRod's Avatar
Make sure to disconnect exhaust at your headers first though. If not you run the chance to break the flange or bend it and get and exhaust leak.
FoxRod is offline
Old 04-17-2006, 07:24 PM
chath_brick
chath_brick's Avatar
i just did this last weekend to change my gasket. i put it up on my friends lift and we had to take apart everything under the oil pan, it took like three hours to get everything apart, 20 minutes to scrape the old gasket off and clean everything and install the new gasket, and three more hours to put everything back on. it sucked. its probably easier than pulling the motor though.
chath_brick is offline
Old 04-17-2006, 07:28 PM
tuff5liter
tuff5liter's Avatar
ORIGINAL: FoxRod
Exhaust isnt even on the car anymore its just the shortblock in the car. was putting on my AFR heads and i decieded I would take some time to fix a couple of annoying leaks while i was at it.
jwog666
12-27-2021 08:09 PM
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
b8checker
09-30-2015 07:11 AM
Quick Reply: oil pan removal
