Axle shaft bearing surfaces?
RE: Axle shaft bearing surfaces?
ORIGINAL: Twisted
Is there a surface on the axle shafts against which metal is rubbing directly on metal. If not, does it matter if the bearing surfaces are pitted/worn a bit?
Thanks folks. I'll work on getting a set tomorrow--if I can find some. I'm having trouble wrapping my head around how the shafts are set up. I had pictured them being suspended on some type of sealed bearing cartridge (like skateboard bearings) that prevented the actual shaft from being a bearing surface itself. At any rate, I wish my manual had more info on axle shafts.
ORIGINAL: 86HOGT
You can make it like that with c-clip eliminators...
Here's what the bearings and seals look like. The axle rides directly on the rollers.
c- clip eliminators, they actually press on to the axle, inner race stays stationary on the axles, the flange bolts to the axle tube and backing plate
ORIGINAL: PRO50SC
As long as they are not totalled all the way around the c-clip elims should be ok. The stock style bearings, not a f'in' chance!! Can you post up any pics of them and is this your rearend noise. I thought all this was being replaced w/ the gear install.
