Cam?
Cam?
i have an 89 mustang gt with bbk headers,h-pipe(off road),. flowmaster american thunder, 3.55, tremec t-5, ford racing 10.5 hd clutch, ford racing flywheel, bbk clutch cable, removed a/c, bbk underdrive pullys, flex-a-lite fan, 3 core radiator, 180 thermostat, pro 5.0 shifter, and a rebuilt driveshaft and a rebuilt posi unit, k &N filter, accel plugs and cap. im going to rebuild the motot with the forged rebuild hit from summit for 469.95, want to put twisted wedge heads, i have a canton oil pan laying around, 24 lb injectors, 70 mm maf and tb,what cam should i buy e303 or f303 because my friend said that the f is too much for the street. im panning on putting 1.6 roller rockers on it and a systemax intake and a mac cold air induction later on. should i go with the f303 at .512 lift and 226 duration at in and ex, e303 at .498 and 220 at in and ex, comp cams magnum at .512 at 230 in and ex. any one who has any opinions please post i really need the help thanx.
Cam?
The stock cam is actually decent... But if you change it, it's really a matter of what powerband you want. The F303 is a little hot,and the E303 could use more duration, so I'd say either a B303 (224*/.480"), or a Trick Flow (221*/225*int; .499"/.510"exh). Both street-friendly and torquey.
My $.02... Good luck! <img border="0" src= smileys/smiley14.gif>
Cam?
<blockquote>Quote: Originally posted by JuiceMan on 20 May 2003<hr>
I've heard that the B303 cam works really good with 1.7 roller rockers, but i dont know from experience thats just what some people have said. Hope that helps.
<hr></blockquote>
The B303 with 1.72:1 rockers actually yeilds more lift than the E303, putting it right between the E and X cams. Good if you want a higher powerband, methinks.
<hr></blockquote>
Cam?
i just put a f cam with my 1.6 rockers and i hhave a hopped up engine and it is perfect for the street. it has a fair idle and lots of power. i had a e cam in there before and i definatly like the f cam better.</P>
Dan</P>
Cam?
but how lumpy is it doyou have trouble going around turns or in heavy traffic? i live in a small town but i still want it streetable and be able to sound nasty at a stop light when those *** camero's pull up next to me and say they wanna race.
Cam?
Hi 89,</P>
The intake you picked is quite large for your combo, you'll be better off with a smaller one like the TFS heat or street. The e-f cams are not that big but do watch out for piston to valveclearances on the stock short block pistonswith the f cam, always check!!!!! Nothing is too big for the street it's just your point of view in a few years you'll be wanting more, tubed chassis, 408 stroker blown, etc.</P>
It's better to have a combo that works well than a poorly working mix match of expensive parts. Such as a big *** intake on a mild engine combo.</P>
Cheers, Shane</P>
