What to do with my '95 GT
I hav a '95 Gt and im wondering what i should do with it. Graduation is comming around and i want some serious power out of it. it is mostly stock except for a CAI. I just want to kno what i should do with the motor? Supercharge the factory?, stroke it?, heads and cam? It has 110,000 miles on it and im worried bout that being too much. What is the cheapest and most powerful setup? Keep it under 6000 if possible. i want atleast 350 HP to the wheels if that is possible.
RE: What to do with my '95 GT
ORIGINAL: SN95Stang
Anyways um ya you can make 350 RWHP with like 3,000.
Do you have and AOD or T5?
If you have a 5 speed id get
King Cobra clutch $150
Pro5.0 short shifter $150
Procharger $3000
Full Mac exhaust which includes Long tube header, H pipe, cat back all 2 1/2 inch $600
GT-40X heads $1000
Edlebrock street heat intake with 80mm TB $700
80mm MAF $200
36 lb injectors $250
That would be alot more HP than 350 RWHP and its around 6k. If your smart you can get some of that used and its just as good as new. If you have some left over get better upper/lower control arms and some Drag Radials.
Just my .02
i would stroke it 347 (then u have a fresh motor) 2000
top end kit 2000
n20 150 shot easy 500-700
injectors 250
mas and tb 400-500
and thats prolly 350 all motor and then u still have the spray for whenever
after that then i would always save up for the suspension and good tires cause ur not going to be able to put all of that power to the ground
top end kit 2000
injectors 250
mas and tb 400-500
