using Tweecer, hard?
Thinking about getting Tweecer program so I can
re-tune computer myself. How hard is it to use? I understand you can go into EEC tell it you have bigger mass air meter bigger injectors read CEL codes adjust emmissions is this right? let me hear your thoughts and what all this program lets you do. |
RE: using Tweecer, hard?
anyone?
no clue. some people say you need to learn how it works.
just think its a neat product.
like having 4 different chips you can switch to on the fly, and self tune if you want too. have street setting drag setting different boost setting 93 octane setting 100 octane setting. all kinds of ideas. i found a guy here in Houston that sells and tunes with em. will just go thru him. www.v8mustang.com. they're only about 30mins away ;) ORIGINAL: Tims 88GT no clue. some people say you need to learn how it works. |
yep it is kool. but when i go twins with my car im going to go with the FAST fmu. can anyone give some imput on this product??????????????????????????????????????????? ?????????????????????????????????????????????????? ??????????????????????????????
ORIGINAL: r.barn How hard is it to use? I understand you can go into EEC tell it you have bigger mass air meter bigger injectors read CEL codes adjust emmissions is this right? let me hear your thoughts and what all this program lets you do. It's not a "I have this installed, adjust yourself to the new parameters" type of system...it's a "when you get this value here, adjust timing, fuel pulse width, etc...to these values this way" type of system.....it requires some involvement from the user/programmer/tuner. Benefit is that you can control and manipulate all the system, but YOU have to make sure it's done right. Hope this explains it a little bit better. |
ORIGINAL: r.barn Thinking about getting Tweecer program so I can re-tune computer myself. How hard is it to use? I understand you can go into EEC tell it you have bigger mass air meter bigger injectors read CEL codes adjust emmissions is this right? let me hear your thoughts and what all this program lets you do. |
