my car cuts out like a miss when i turn sharp!
whats up fellas!! ?? my car cuts out when i turn sharp is it the gas sloshing from side to side it never did it till i rebuilt my engine is there a cure for this ? thanx
RE: my car cuts out like a miss when i turn sharp!
are you carbureated or FI?
What you hear is the gas in the tank sloshing..not a big deal by itself... If you're carbureated, it could be you need a new needle and seat valve and float in your carb If you're FI you may need a new pump with a slighlty higher flowrate to keep it from missing... |
No he is SEFI. how much gas was in the tank?
A couple possibilities exist like mentioned above.....
Broken baffle in the gas tank, sloshes around with the fuel, & covers the fuel pickup on a sharp corner common on fuel injected 5.0's...... |
YA! it is fi i have brand new injectors in it steped up a little in hp so i might need a little bigger pump?
well the tank had about 10 bucks in it
could be the stocker is not very good.
how much is gas? 25 only got me half tank 3.03 a gal
ORIGINAL: 1BADASSLX well the tank had about 10 bucks in it i think you should plan on upgrading the pump. When you go to replace it; you can feel the baffles & tell if one of the spot welds has broken or not..... If one is broken? Well.... life gets a little bit more interesting.... |
yep
