Hot restart stall issue
I have a stalling issue with my '88 GT automatic. When cold, the car starts right up and idles perfectly.
Put the car in gear and down the road with no problems.
The issue is a hot start stall. After the car gets to temperature, the car will stall when retarted when put into gear.
The car will start and idle fine. as soon as I put it into gear, the car dies. I have found I need to rev it past 1200 RPMs,
quicly put it into gear, and tap the gas to get it going. Otherwise it will choke and stall.
I have changed the distrubutor cap and rotor, metered and adjusted the TPS to .95 volts, changed out hr TFI module, cleaned the EGR, Cleaned the throttle body, and replaced the coolant sensor. Any ideas?
RE: Hot restart stall issue
ORIGINAL: cheetha94607
had the same problem eith my 91 lx found out the tfi module was starting to go bad(located on the distrubitor).
also last year i had my 9al (eec) to cause the same problem
so did you replace the distributor? and what is the eec?
trashxtrash
09-20-2015 10:49 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
zanemoseley
09-06-2015 12:58 PM
