weared noise
![Default](https://mustangforums.com/forum/images/icons/icon1.gif)
It's probably your uh...muffler bearing getting warmed up. [sm=bustedsign.gif]
Yea dude...squealing is your belt. Do you know where your belt tensioner is? If not...it's right next to your alternator. There is a belt strength guage. When it is loose...it will get closer to the bottom (or is it top?). At any rate...if it's not in the middle of the guage...best bet is to get a new serpentine belt.
PBH 4060905 w/ ac 27.15 from NAPA
PBH 4060845 w/out ac
Hey man, I bet $10 its your belt. Check the tensioner and see if it is between the proper tension area. And then try the soap trick, if it quites swealing when you put soap on it then its the belt.
