Carb Conversion: What Edelbrock Intake to buy?
#21
RE: Carb Conversion: What Edelbrock Intake to buy?
ORIGINAL: deadcarnahans
Holleys are are junk. They leak fuel and are a bear to tune. Stick with EDL for street use.
#22
Edelbrock carbs are really Carter AFB's which first came out 9/56. Thats about 9 years before any GM quadra-jets were made.
Holley/AFB thing never seems to go away. If you tune the AFB right an engine will make the power as it would with a Holley assuming they were both the same size.....
IMHO, Holleys are a little easier to work with as the parts are easy to find.......
#25
ORIGINAL: OJMiles
Will the Air Gap cause me to have to use an aftermarket hood? i want to stay under my stock hood if at all possible.
-- OJM
-- OJM
This is the only real choice for stock heads and no concern for power over 5500 RPM. The other experts are recommending manifolds that have larger port dimensions which mismatch with the stock heads, impairing flow and torque. Drivability will suffer, especially with an automatic. If you don't believe me, e-mail an Edelbrock tech.
As far as my bold opinion of Holleys goes, I stand by it. All the teflon tape in the world would not help me. Mine did not leak at the fittings. They dribbled from the secondary shaft, and the O-rings on the transfer tube leaked too. Also mysterious casting defects cause uncurable leaks.
Fuel leaks are not an option for my vehicles!
#26
Use the 2121 that you successfully researched own your own.
I don't believe you and I'm not calling Edelbrock tech evah again. Proof you are wrong about the port size....
http://www.holley.com/8020.asp
Stealth ports size: 1.83†height 1.02" width
http://www.edelbrock.com/automotive_...-air-gap.shtml
RPM air gap Port exit dimensions: 1.04" x 1.85".
If we are splitting hairs, the Stealth has SMALLER port size.
#27
newb wont back down and accept defeat. Ive had both the holley 600 vac sec and edelbrock 600 vac secondaries and had them tuned by the same guy and the holley is the better carb and Ive had plenty of holley carbs and ive yet to have one leak, then again everytime i get one i put a rebuild kit into them while i have the carb off because it saves alot of hastles with leaks unless its a brand new carb then I dont mess with it.
09-08-2015 11:50 AM
09-01-2015 08:16 PM
