torque converter?
torque converter?
ok well i have to drop my tranny to replace my main seal but while its out i want to throw in a converter. the onlt problem is which one? i heard tci is pretty good or i was thinking about performance automatics or lentech. how high of a stall do i want. its a mild modified motoe just bolt ons no heads or cam. i was thinking about 2800-3000 stall? any help would be great
RE: torque converter?
"stallion" from precision industries.
DO NOT GO LOWER THAN 3000 !!!!!!
you will kick yourself if you do...trust me no matter what anyone says.
i had a tci 2200 in my older car , w/ 3.73's and the motorsport low gearset for the tranny it still bogged if i wasn't by myself.
ORIGINAL: nitrous_bob
ok sorry to bump this up but how do you measure what size torque convertor you need for the flexplate? I've got a 3000 stall already just need the correct flexplate to fit it. Do you measure from bolt to bolt or what?
go with at least 3000 and whoever you use it needs to be a custom for your car weight rear ratio and horsepower if not you may end up with more or less stall than you want
i have used ptc out of alabama back when i was young and had great results
