looking for more......
i just got done with a full rebuild, new pistons, balaced, TFS top end kit (heads, cam, intake, 1.7 RR's, Timing chain ect)
put all new sensors , fuel pump water pump plugs, wires, coil
3.73's, tremec trans, Steeda Tri Ax shifter, 70mm TB with 75mm mass air, underdrive pullies, 3in radiator
what next? suspension and what else, i need a few ideas
RE: looking for more......
you need to get your chasis and suspension up now.
then do a blower/turbo
I'm about to put the MM Road & Track package on my car.
lowering springs, shocks, L/C's, sub-frames, plus lots more.
http://www.maximummotorsports.com/giab2.asp
ORIGINAL: white93 GT
ORIGINAL: frop
Don't forget brakes, crashing isn't fun.
horsepower is great, but stopping power is better. it saves you from losing all the money you've invested (spare that someone doesn't hit YOU) or worse. that's why i don't like vipers, fast as hell, but can't stop for ****!
rear disc is def a good idea. are your fronts stock? i would suggest upgrading them at the same time. it's not 100% necessary, but you dont want your rears working better than your fronts.
CyprusMustang
03-30-2009 06:39 PM
