Mystery oil leak
RE: Mystery oil leak
^^^yes he has. i know how to find it, klean off old oil. make it nice and klean to. then start the car and stick ur head in the engine compartment and look to see where it leaks. might take a while but im sure u will find it.[sm=roll.gif]
ORIGINAL: Grimace5.0
I was thinking about that today when I was changing the oil and looking for the leak. The bottom of the pump has drips on it. I wasn't sure if it could leak oil or not. I will get another and see what happens. Thanks for confirming, you the man!
ORIGINAL: PRO50SC
Ok you know the f/p can leak oil right? Have you ruled that out?
What kinda breahters do you have on the valve covers? I had one leaking oil from there once. I was thinking of the valve covers also, if you have a quark gasket. make sure you didnt kink the gasket, i did that once to and i leaked oil from there. The oil has a habit of coming up from under the valve cover bolts on my engine. I put a little silcone of the tips of the bolt before i run it in the hole.
ORIGINAL: PRO50SC
No problem, I had to dig way in the back of the filin' cabinet for that one. It's been quite some time ago!!! LOL!
ORIGINAL: PRO50SC
ORIGINAL: 88stangaruu
by the way grimace, your car just got put on my computer background. Just to let you know. I like 86's. Always have. First 5.0 i ever rode in was an 86.
