Mystery oil leak
Mystery oil leak
Well I have a mystery oil leak. No clue exactly where it's comming from. My car is old school it has a mechanical fuel pump. You EFI guys probably never heard of such a thing LOL. Anyway, the fuel pump is on the drivers side of the timing cover. The oil is dripping/spraying/flowing/whatever onto the top of the fuel pump. What makes it bad is the electric fan blows the oil all over under the hood. So everything on the drivers side has a oil film on it. Making it hard to locate the actual source. I changed the fuel pump gasket thinking that it was leaking. Still have oil all over. I reconfigured the oil pressure gauge line thinking it might be the source. Still have oil all over. Today I changed the valve cover gaskets...hoping for no leaks. I don't know what the heck else it could be? Maybe the timing cover has a crack in it? Ideas?
RE: Mystery oil leak
I'd check the timing cover and gasket. Is there any oil sitting in the valley ontop of your water pump just below the dizzy (front intake gasket is what im thinking about). Other than that, unless the front of your oil pan is leaking and when you drive the air pushes the oil up and into the path of your electric fan which tornados it across your engine bay i dunno. Should be about all the gasket that could be your problem with the one's you've changed already. Good luck man!
Edit: Check the torque on the oil pan and make sure the bolts are tight, as well as the other bolts around your problem area that could have worked loose.
Damn thats kinda odd, There shouldnt be any huge leaks around there.
I mean the oil pump sender is on otehr side and theres no pressure lines around there.
Only thing I could think of is valve covers, or oil pan. And I cant see how the oil pan can shoot up on the fuel pump.
ORIGINAL: marx91
could the line going into your oil press. sending unit be loose?
ORIGINAL: PRO50SC
Ok you know the f/p can leak oil right? Have you ruled that out?
