Not Chilton or Haynes
#22
RE: Not Chilton or Haynes
well each manual will give part numbers to every part that goes in a vehicle. As far as bolts go... some bolts have part numbers, others don't. It just depends on if the engineer who wrote the book intended that perticular bolt to be carried in stock.
#26
if ya'll think the vehicle manuals are thick... well... you're right! the manuals give step by step instructions on exactly how to remove and reinstall each component on the vehicle... the problem with those manuals is that ford makes mistakes (go figure)... sometimes... but not all the time.
I know, that's not the information you wanted me to tell you...
#28
well if it makes you feel any better I usually end up wanting to strangle the engineers whenever I'm trying to figure out certain pin point tests that don't work or make any sense... If you ever get the code C1440... be prepared for the pin point test to tell you to replace the ABS module... even though it's fine... yeah... I wanted to strangle the engineer that day.
