frequent drop in oil pressure.
RE: frequent drop in oil pressure.
well assuming your engine hasn't started going metal on metal or wiping bearings I'd suspect the guage and/or sender... since the guage only really reads what the sender tells it to that narrows it down to the most probable (but not guranteed) component at fault: pressure sending unit... replace it... you'll probably be alright... it's probably just fouled up somewhere.
that seems like good idea. ill check that out. is only done it like 10 times in 2 or 3 months. it must be clogged or going bad. where is the sender located?
lol...ill look for it tomorrow. [8D]sometimes i wonder myself.
ORIGINAL: Tims 88GT
^^haha i dunno if i believe u have a 347 anymore. umm it should be behind the ps pump
ORIGINAL: Tims 88GT
hrmm... wait... I need to know what motor you have....
