should i have it balanced?
Old 04-23-2006, 03:45 AM
ikeybmg
ikeybmg's Avatar
Default should i have it balanced?
the vic jr heads i have make power between 3-7k. the rpm II im getting is 15-6500. would i be better off having my motor balanced to get more rPMs from it. how much would it cost for someone to do it if its already together. would it be worth it?
ikeybmg is offline
Old 04-23-2006, 03:46 AM
Tims 88GT
Tims 88GT's Avatar
Default RE: should i have it balanced?
u cant balance a motor thats togeater.
Tims 88GT is offline
Old 04-23-2006, 03:47 AM
Krusher
Krusher's Avatar
ORIGINAL: Tims 88GT
yup... and...
if it wasn't balanced you'd know...
Krusher is offline
Old 04-23-2006, 03:48 AM
Tims 88GT
Tims 88GT's Avatar
motors are not balanced from the factory
Old 04-23-2006, 03:50 AM
Krusher
Krusher's Avatar
hrmmm... really?
TSB
03-21-19
ISSUE:
An engine vibration and/or "moaning" noise at 2600-3000 RPM may occur on some vehicles. This may be caused by an imbalance within the engine, flywheel and clutch.
ACTION:
Add a known mass value in the best location on the clutch to reduce the vibration and/or "moan." Refer to the following Service Procedure for details.
didn't know that...
Krusher is offline
Old 04-23-2006, 03:51 AM
ikeybmg
ikeybmg's Avatar
yea thats my point. would it be worth having it all took apart to do the balancing.
ikeybmg is offline
Tims 88GT
Tims 88GT's Avatar
he means internaly blanced
Old 04-23-2006, 03:53 AM
Krusher
Krusher's Avatar
the reason why that TSB happened is because of an imbalance... an imperfection... we had to balance the engine so that it would go away... engines are normally balanced... if they weren't the frequency and the amplitude of the engine would be off the charts, no matter what isolators we used.
Krusher is offline
Old 04-23-2006, 03:54 AM
Krusher
Krusher's Avatar
ORIGINAL: Tims 88GT
AHHHHH... that my friend would be a pain in the ***... never heard of it so I couldn't comment about making an external balance into an internal balance... I'll ask on monday if you want me to.
Krusher is offline
ikeybmg
ikeybmg's Avatar
yea im talking about internal. bal'd and blue'd
ikeybmg is offline
Quick Reply: should i have it balanced?
