Problem Removing Factory Dizzy???
Well while adjusting the timing I snaped the TFI module off!!! Now I need to completely remove the dizzy to fix or replace it. Its the ground tab, but anyway the thing will not come off. I removed the bracket, but that thing is on there. What am I missing here? Shouldnt it just slide out?
RE: Problem Removing Factory Dizzy???
yea, you cant just give it a yank.... you sometimes have to help the rotor rotate counter clockwise.... but it should come out fairly easily.
just make sure you mark where the rotor is when you pull it out, or you are going to have a hard time re-stabbing the dizzy
