quad shocks
RE: quad shocks
quad shocks control axle rotation under load and keep
axle from hopping under high toque.
you can take them off if:
1. upgrade lower and upper control arms, also get a panhard bar
to keep axle in place from side to side.
2. best way to replace the job of the quad shocks is to
switch to 3 link with Torque Arm and new lower control arms
then you can remove quad shocks and upper control arms.
car will handle MUCH better also.
RE: quad shocks
if your going to do any kind of racing, you may want to get a set of adjustable uppers so you can set your pinion angle to properly work with the load of the rear end so you dont get u-joint bind. I am building my car to be streeted, so i just stayed with hard uppers and lower... non adjustable, but greasable
