rear end rebuild
#22
RE: rear end rebuild
Get the last kit, it is better to rebuild the wholething and not have any worries later on, thats what i did with my 94 gt i did it all myself and then had a expert check it for 100 bucks and it was little off, but i got the piece of mind knowing everything is brand new even if it was a ton of work.Plus for every new bearing you get you need the new race for it because of the wear patterns in the old ones.
#25
im in the middle of rebuilding my rearend aswell, if u want u can redo your stock carrier, all you need is a set of clutches, and check your spider gears as well, then buy something like a Precision Gear master installation kit, comes with everything you need.
I bought Brand new Precision Gear 3.73, Precision Gear Master installation kit, MAC Girdle, and a FRPP 28 spline T-lock carrier...now everything is brand new!
#26
does #3 come with clutchs? are the shims just a different word for clutch? or do i need to separately buy the clutchs? also, will the clutches fix my one wheel burnout problem?
#28
will this work? its hard to find ones with the clutches...
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
how about this kit gears and rebuild, then i just buy the clutches...
http://cgi.ebay.com/ebaymotors/3-73-...spagenameZWDVW
#30
youll be in good shape
ORIGINAL: ckyguy68
