rear end rebuild
rear end rebuild
i am getting 3.73s and i need to know what i should get with them. i know my posi clutches are bad because sometimes when i burnout only 1 wheel spins. what else should i get with the gears? also, can i use ANY 3.73s that fit an 8.8? what do you guys think about used gears? thanks!
are these ok?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8057770324
are these ok?
RE: rear end rebuild
^^^some plcaes will charge you anywhere from $400 to $1000.
used gears are like everything else...just look closely at the ring gear for chips or flat spots.
the pinion usually just chips....
so i should be ok buying the ones in my link?
ORIGINAL: grabbem88
