Throw out Bearing
RE: Throw out Bearing
if you have a bearing making noise , weather its the throw out bearing , or a wheel bearing , pinion bearing ... whatever you got to fix it.. if your gonna tear it open you might as well do the clutch .... if you just want to replace the bearing you can do that too... most all the replies here have been good advice... a clutch cable will not make a noisy worn bearing better. good luck
KingRando
10-02-2015 08:06 AM
Offendant
09-23-2015 07:21 PM
